Fa11ou7
- Mar 3, 2012
First off, Thanks so much MLE and everyone else that has and will contribute to this thread you guys are amazing!
[size=10pt]I've been reading through this thread trying to glean as much information as I can. I think I have made my decision on what setup I am going to get but I thought I should post it and see if you guys catch anything I'm missing. [/size]
[size=10pt]I play games mostly on my PC but I also have an xbox that I use from time to time. I need (want) a pair of headphones that I can use with either system that will give me this DH surround that sounds so amazing. My PC doesn't have a sound card just what is on the motherboard (asrock 870 Extreme3) which claims to have "[/size][size=9.0pt]7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec)" [/size][size=10pt] and it does have optical out so I can hook that up to any of the DH systems previously mentioned. I haven't been able to trick it into giving me surround on my headphones but maybe someday I will try and figure that out. [/size]
[size=10pt]I am most definitely not an audiophile and I do have some hearing loss which decades ago the audiologist said I should never use headphones...... ya that didn't last long. I did research here a few years ago and got a pair of nuforce IEMs that I find to be a much better sounding option than the ibuds that I was using, as long as you don’t move to much. I also have a pair of Sennheiser HD 435s from work that sound pretty good to me and I hope would work plugged into any of the DH amps that I will buy. [/size]
[size=10pt]I hope to spend no more than $150(US) so after reading through this thread and checking prices I would love to get the Astro mixamp 5.8 but just can’t justify the cost since I can’t get it separately from the A40s which most of you have rated poorly. Someone earlier gave a glowing review of the TB PX5 and those have the added bonus of wireless (mostly) and built in mic. I figured for movies or single player I can just plug my 435s into the wired headset port. I also found them used on amazon (90 day return policy) for $130ish which seems like an amazing steal. After that I would probably just try the DSS2 or AX720 for the amp.[/size]
[size=10pt]So there are my loooong musings if anyone has some input they would like to give me I would appreciate it, and thanks for wading through my post.[/size]
Ps – Any thoughts about the TB X42s that are going to be released in April?
