I'm still a bit confused about which Beyers would be the best option for me. It seems like the DT 880 is the most neutral of the three and has good clarity in the mids for things like vocals/voices, and the DT 990 has "brighter" highs (which can apparently cause badly recorded material's high notes to sound worse and in my case might exacerbate the sensitivity problems with the highs) and has more bass but because of that, it supposedly makes the mids sound recessed compared to the DT 880. The DT 990 also apparently has a bigger soundstage. I don't know which of the two would make for better gaming headphones, though. Impedance-wise, Zombie_X made it sound like the 600 Ohm versions would be what you should go for if you can.
Honestly, I can't answer this. All I know is the chip name (Realtek ALC892) and what its listed specs and capabilities are.
PurpleAngel, from what you're saying as far as the sound card stuff goes, the Xonar would probably be the one I'd want since it has Dolby Headphone and also has a built-in headphone amp on the headphone out that's supposed to be rated for up to 600 Ohms, which I'm guessing removes the need for a separate amp. I don't know if that rated output is true and would be enough to properly drive something like the 600 Ohm versions of the Beyers, though. I've also noticed people around the web saying that they've had issues with the Xonar's drivers causing certain games to crash, because of things like the game using outdated OpenAL drivers, or the "GX" mode conflicting with the game somehow. It doesn't necessarily sound like a huge issue, but it's something that you may have to work around if it comes up.
I would say to get something that's 250-Ohm, a few have said the 600-Ohm is only slightly better then the 250-Ohm.
If you spend like $350 or more for a nice external headphone amplifier, then the 600-Ohm might be worth it.
I can see older games from the Windows XP era would have more problems with Asus Xonars.
Back then Creative Labs EAX 5.0 was the thing to have for gaming, Asus Xonar will use GX 2.5 to try to emulate EAX 5.0, but it's not perfect.
Windows audio changed starting with Windows Vista/7, so the newer the game the more stable it should be with Asus Xonars.
Game makers are less dependent on EAX for newer games, starting with Windows vista.
I believe Asus Xonars use a 100% software driver for OpenAL.
The Xonar audio processing chip, the C-Media CMI8788 (CMI8786 for the DG) OpenAL drivers would (guessing) be written by C-Media.
Third party Xonar drivers (Unified Asus Drivers) only use a slightly newer OpenAL then the official Asus drivers.
So using Unified Asus Drivers should make the OpenAL work better.
I stopped using Creative Lab card around 3 or 4 years ago, last one was the Titanium (non-HD), not because of the sound quality, but the pain of fixing and reinstalling Creative drivers.
Some have said the creative drivers have gotten better starting with the Titanium HD.
