PS3/4 can do that?
Mad Lust Envy's Headphone Gaming Guide: (8/18/2022: iFi GO Blu Review Added)
- Thread starter Mad Lust Envy
- Tags
- akg-k612-pro-reference-studio-headphones akg-k712-pro akg-q701-premium-class-reference-headphones-quincy-jones-signature-line astro-a40-audio-system-white audeze audio-technica-ath-ad700 audio-technica-ath-m50-studio-monitor-headphones beyerdynamic-dt-770-pro-80-closed-studio-headphones hd800 hd800s headphones over-ear philips-shp2500-37-full-size-headphone-with-volume-control sennheiser-hd-598 shure-srh1540-headphones sony-mdr-ma900-over-the-head-style-headphones sony-mdr-xb700-50mm-xb-diaphragm-driver-extra-bass-headphones soundmagic-hp200
Jason Bourne
- Oct 7, 2012
PS3/4 can do that?
Yeah for blu-rays that are DTS only you can get Dolby Digital signals by selecting "bitstream mix" in the menu on the PS3/PS4. Im wondering if there is a similar option on the XBOX One...
Silverwind
- Jun 10, 2014
Sweet, can't go wrong with the X1 IMO. They're a great all-arounder and really fun. If you find the bass to be too loose, an amp helps.
I am going to order the monoprice "mobile audio" 3.5mm cable for the headphones. The price is right.
SonnyA85
- Mar 24, 2014
Sonny just before ordering saw that DG is a PCI card, dont have a PCI slot, have only PCIe. So the DGX which I read is equivalent to DG will really be the same? Should I go ahead and order the DGX?
Sonny, thanks for all your replies, I am now either buying 558 or may pick a used 598 from a friend who is thinking of selling them. It will cost the same to me, used 598 = new 558. I guess thats ok deal?
if you can get a HD 598 for the same price as a HD 558 then it's a no brainer, buy a used one and you can either clean the pads or replace them.
As for the sound card if it's for gaming only you can even use Asus U3 which is USB, it doesn't sound as good as the DG or DGX but it is good enough.
If you want to play high fidelity music as well these sound cards are good for the money, but in future you may want to upgrade to a DAC/AMP. For gaming though a cheap asus sound card with built in headphone amp is all you need.
I would also use the "unified drivers" from here
http://maxedtech.com/asus-xonar-unified-drivers/
the official drivers are rubbish
Hey huys, have You seen Astro's E3 presentation. They've announced A50 usb wireless transmitter for about 40$. It has the same functionality as the existing one but it's usb only and cheaper.
- Mar 20, 2010
The Xonar U3 = external Xonar DG, FWIR. Not sure how correct that statement is, but signs point to it being true.
And Change, yes, hiatus. I have no desire to try/review any headphones up until I try the HE-400i. Someone could send me an SR009 and I still wouldn't want to try/review it. I'm not going to spend any money on this hobby for a good while. The HE-400i may or may not happen, leaning on WON'T.
SonnyA85
- Mar 24, 2014
http://techreport.com/review/21256/asus-xonar-u3-usb-audio-device/2
DG is better
Are the K702 65th Annie worth getting instead of the Q701 for gaming? I own the already. I play open word games and fps so I like immersive and spacious headphones that are nice and textured.
Murder Mike
- Jan 15, 2013
You own what already?
In my personal opinion, the smooth headband and memory foam ear pads make the K702 Annie worth it to me over the Q701. I wasn't happy with the the bumpy headband on the Q701. The ear pads are a preference thing, but they're around $70 separately, so you might as well have them included. Blue is also my favorite color, so it was an obvious choice.
The Q701 can be found used for around $130 or $140 on the Amazon Warehouse. If you don't mind the headband, it's a very solid deal. If you picked up the memory foam pads later down the line, most people agree that you would have a headphone that sounds 99% like the Annies.
SonnyA85
- Mar 24, 2014
The annies are nearly £400 here whereas the Q701 are around £200.
IMO the Q701 are much much better in terms of value for money. It depends on how much you can get either for (brand new).
I have never tried on mine, sorry. I use an AVR so I'm fine with either.
I haven't but I'll check it out. I'm not sure what you're talking about with the transmitter tho. Is that like a replacement in case you lose or break the one that comes with the A50? Cus that's a pretty niche product to get excited about. I was hoping for a new wireless Mixamp...
It's more like a cheaper replacement, it does dolby digital over usb. Handy if you're a pc gamer
Jason Bourne
- Oct 7, 2012
For blu-rays that are DTS only you can get Dolby Digital signals by selecting "bitstream mix" in the menu on the PS3/PS4. Im wondering if there is a similar option on the XBOX One...
Anyone?
Anyone?
Not a lot of people in here with Xbox One as far as I know. You might try asking over on the actual Xbox support forums?
Jason Bourne
- Oct 7, 2012
Thanks for the replies. I guess your right, will give it a shot.
Total: 18 (members: 0, guests: 18)
