You guys do know there is a dedicated thread to debate this on, right?
Hey, I think Evs should make a movie about the differences between the Mixamp, Recon and DSS.
I would so love to see Ev in an action movie! Using Recon to fight off Mixamp and his DSS soldiers!!!
Oh I was picturing something more like this...
Hahaha! Nice! Coming this summer to a theater near you!
Stillhart,
How are you liking the Omni? Does the Omni>Optical Modi>M-Stage work well for music? I'm thinking of purchasing an Omni and Optimodi as well as the Vali for the ultimate PC virtual surround setup. You have it going from USB to Omni to Optical out on the Omni and then on to the Modi then out to the amp, correct?
Not sure whether to buy an internal or external sound card for my PC. I definitely have room for an internal as I'm not running my GPUs in SLI. I'm thinking of keeping the Mixamp as my console gaming device and buying either the Omni, another external 5.1 card or an internal card. Not quite sure which route to go though.
Stillhart,
My Omni just returned from a loaning spree, also just last night finished reprogramming my "hotwired" wifi for my computer, and then this morning $1000 worth of mail packages arrived (just before work, didn't have time to open)...
It's interesting, going from using my Q701 straight out from my Recon3D USB (sometimes using the E12) for a few months to finally getting to use the Omni, I'm pretty comfortable saying the sound is sweeter and easier on the ears... with the Q701 just plugged straight in. I am again impressed by the Omni.
Soon I will also be chaining my optical DAC (one of the mail packages) to my Omni, and reconnecting my Tube Amp for the first time since moving, and I've got my K712 back (in the other mail package, along with another borrowed headphone for review), so hopefully the heavens will open up and rain "Autonomous Sensory Meridian Response" upon my spine
But seriously, my Omni plugged straight into my USB3 port on my desktop computer IS clearly an upgrade from the console processor/DACs. Those are no slouches and adequate for gaming, but the Omni is more funAnd, I did not notice much difference going from SB Z to Omni. I say pick one of those two, since you can later upgrade as high as you want later with an Optical DAC and external amp. I chose the Omni because it's also Mac-compatible, so I can use it with whatever next computer I get or share with laptop users.
Only thing I've gotta figure out? How to plug in both the amp and DAC to clean power, plugging into my Monster power strip adds noisiness and weirdness.
What optical DAC did you end up getting? You'll have to let me know how much it helps with the Omni. I want to know whether or not to buy a DAC as well when I end up ordering the Vali (it costs the same for shipping to order one Schiit product as it does to order two).
Also, when I use my Mixamp with my K712s, the harshness of the highs seems to be increased a bit. Did you see a noticeable reduction in harshness with the tube amp and your AKGs? Does the Omni also reduce the harshness?
Tubes aren't inherently warm... Cheap ones can be kinda wooly, but good NOS ones (steals are available on eBay!) can have a superior sense of detail and soundstage separation... But there's a lot more variety in tubes than in SS-amps.
Sometimes, you don't have to reduce the treble (via EQ or a dark amp) to avoid fatigue; sparkle isn't mutually exclusive from sweetness and smoothness.
