Mad Lust Envy's Headphone Gaming Guide: (8/18/2022: iFi GO Blu Review Added)
Feb 25, 2014 at 1:37 AM Post #21,241 of 48,566
So the PSB M4U 1 and 2 are compatible with the BoomPro?
Wow, they're expensive. The 1 seems more ideal, as it doesn't have the noise cancelling feature, which tends to make headphones sound worse than their non-NC versions.
Feb 25, 2014 at 2:06 AM Post #21,243 of 48,566
I looked at some unboxings, it looks like standard 3.5mm cables, so I'll take it as a yes. Still, I'll be waiting for your post.
Anyone here getting Symphonia Chronicles? I have a question: Does the back cover state it supports Dolby Digital? They're relatively old games, and I'm guessing it's gonna be stereo.... with MAYBE Pro Logic II at the most.
Asking because, I bought the game digitally, so I can't tell.
Feb 25, 2014 at 7:05 AM Post #21,244 of 48,566
You make sure everything was set up the same? Also, do a speaker test in the devices menu. Sometimes it likes to stick to a messed up 2 channel even when you chose multiple.
Yes, every settings are the same like when I used the u3 Somehow the DH surround effect feels weak compared to the u3, especially the rear sound.
Maybe its just my feeling, but i think better to stick with the u3.
Feb 25, 2014 at 7:57 AM Post #21,245 of 48,566
It doesn't make sense. If the settings are absolutely identical, the surround effect should be the same. Perhaps you have one stuck on DH-1, while the U3 is on DH-2...
That or the software is properly set up, but your default settings for speakers isn't on 5.1/7.1.
Feb 25, 2014 at 10:01 AM Post #21,246 of 48,566
Thanks for reminding me to add that to my slickdeals alerts. I forgot all about it. The only thing I could find in relation to your question was a JP rear box shot that had Linear 2CH PCM on it. So probably stereo.
Feb 25, 2014 at 10:13 AM Post #21,247 of 48,566
Yeh, played a bit today, definitely stereo, so I'll be using my TV speakers for this.
Feb 25, 2014 at 2:43 PM Post #21,248 of 48,566
Just wanted to let you know that the V-MODA BoomPro also works with the updated Skullcandy Aviator that has the removable cable (SKU # S6AVDM-XXX).
Feb 25, 2014 at 4:25 PM Post #21,249 of 48,566
If you plug those into the PLAYSTATION, I think it will work.  The wiring will be a bit messy and controlling game/voice will have to be done manually.
I don't think the DSS is able to see those little USB soundcards though, only USB headsets like from turtle beach.  So I'm pretty sure you can't plug them into the DSS.
Feb 25, 2014 at 5:06 PM Post #21,251 of 48,566
My USB keyboard worked just fine with the USB port on the DSS, so there should be no issue with that. Thanks for the help, I'll let you know how it goes. :wink:
Feb 25, 2014 at 5:10 PM Post #21,253 of 48,566
Ahh.  The USB port may act as a passthrough then...
Feb 25, 2014 at 6:52 PM Post #21,254 of 48,566
I think so. It even recharges the controllers just fine.
Feb 25, 2014 at 10:38 PM Post #21,255 of 48,566
The BoomPro does NOT work with my PSB M4U2 headphones. I guess now i have to wait for the ModMic 4.0.
What other options do I have at this point?
It should work with the M4U 1. The cable is a standard 3.5mm cable. Don't understand why you need active noise cancelling unless you're on a plane or loud train...
Regular sealed headphones should be enough for daily use if you just need to keep quiet, or keep moderate noise from bugging you. I'll update the first post.
