skullguise
Have a friend who bought a business, came with several old Powermac G3's. Small local network, 4 machines, not connected to internet.
He has some data on it he needs to back up, about 1/2 a gig worth (2 files @ 256M each). None of the machines have CD-R's, they have Zip drives but they are 100M drives.
I was able to install a PCI USB card in one machine; the hardware is recognized, but the USB functionality is still not working. It LOOKS like it needs USB drivers loaded from the OS install CD.
My friend can't find the CD. He's trying to contact the original owner to see if he knows where it is/they are.
The OS on that machine is 9.2.2; the other machines are 8.6.
I can borrow a 9.2.1 OS CD to see about installing/adding in the USB drivers.
My questions are:
- Do you know if I can use the 9.2.1 OS CD to add USB to the 9.2.2 OS?
- If I get it working, can I use a flash drive formatted for a PC (I would assume FAT or FAT32) in the Mac (IE, can I initialize it for Mac use)?
I'm also looking at other options, but need to either find hardware or need to confirm something is workable.
- Find a SCSI CD-R and compatible software
- Find someone with a newer Mac with CD-R drive to connect on the network and back up the data - can this work?
Any info appreciated. I've started to look online, more at the file sharing with newer and older Mac OS's concept. But I'm hopefully close with the USB solution, so wanted to see if that would work.
Thanks,
Todd - skullguise
My questions are:
Thanks,
Todd - skullguise
