Originally Posted by GregVDS
(VU meters)
How to do that? take L and R signal, and then after? Assuming the VU meter sensitivity is 0-200µA (130µA = 0VU) and resistance is 250 ohms, what should I do (348-8425 part number RS-components)?
I guess this depends on what you're trying to accomplish with the VU meters (actually measure something or just for visual amusement).
If you want to be pedantic, the IEC and ANSI standard for VU meters is to display 0VU at +4dBu (which corresponds to a bit over 1.5Vrms into a 600Ω load). If such a meter is to be connected to the output of a headphone amp, you'd probably find that most of the time it shows little motion at all because the output voltage while driving headphones at average listening levels is far lower than that (see below).
Therefore, you might say that you really aren't trying to conform to any standard. Then the question is, what should the "0VU" reading mean? Maximum output of the amp? Some arbitrary level where you get the most meter activity?
Headphone amps can output a very wide range of voltages depending on the situation. The amp is capable of delivering many volts of output prior to clipping, yet depending on the type of headphones you use the "typical" level could be as little as millivolts (for example, the Grado RS-1, a low impedance headphone, is rated to output 98dB SPL with just 1mV, and that's quite loud). Higher impedance headphones tend to require higher voltage to reach the same loudness. Headphone sensitivities also vary from model to model, so at the very least we're talking 2 to 3 orders of magnitude difference in voltage levels between those extremes. That's over 60dB of dynamic range.
The meter you specified has only a usable display range of just a bit over 20dB. If you set the meter up to get a useful range of motion (for whatever it's worth) with a Grado, it might be quite a useless range for a Sennheiser.
As such, I think it should be clear that VU meters on a headphone amp are of dubious value.
As for the particular VU meter you linked to, it doesn't look like a proper VU meter (good VU meters are a lot more expensive than that). I defer you to the following site for more info (courtesy of Elliott Sound Products) about VU meters and their drive circuitry:
http://sound.westhost.com/project55.htm
