Low end. Cheap. Generic. Otherwise bang for buck cable thread!
Apr 11, 2024 at 4:07 AM Post #9,106 of 9,241
Thinking of buying some new speaker cables.
8' long, not bi-wired. Speakers: Linaeum 10, Nominal impedance: 8 ohms, goes down to 6 ohm but nothing difficult. Sensitivity: 88dB.
I'm considering BJC Twelve White Speaker Cable
or
Supra Classic 2.5.
Thoughts?
Apr 11, 2024 at 10:39 AM Post #9,107 of 9,241
or
Supra Classic 2.5.
Thoughts?
In my experience, Blue Jeans cables are a fantastic baseline.
Apr 13, 2024 at 8:08 PM Post #9,109 of 9,241
Can anyone recommend a good quality nylon braided balanced 4.4mm or modular with 2pin connector cable?
Apr 13, 2024 at 11:04 PM Post #9,110 of 9,241
Got the Hakugei Thor and Moonstone
Apr 14, 2024 at 12:35 PM Post #9,111 of 9,241
Two promos from ivipQ/ZiSin twitter:
ivipQ Value Lucky Bag for $24\$42 with promocode
Code:
MJWH3TI2LRFF
https://www.aliexpress.com/item/1005006830966173.html
No hints about contents of these.
ZiSin-29 4-Core Litz Upgrade Cable for 18-24$ (price may vary for you, depending on additional coins discount) with promocode
Code:
ZISIN299999
https://www.aliexpress.com/item/1005006828096016.html
ps: Their ZiSin-27 (non-modular, lighter in color) cable is quite nice, especially for it's real price of $9.9. This time though they are not hiding the code.
Apr 14, 2024 at 3:03 PM Post #9,113 of 9,241
Apr 15, 2024 at 11:52 AM Post #9,115 of 9,241
Next batch of cables have been in for a week or so...
NiceHCK SnowCat: Very nice Silver plated OCC cable with a lift in bass and treble. Resolution seems to be about average for an OCC cable. It's not quite as nice sounding as my Tea 2's stock 6n OCC Silver Plated cable, but it is built much better, is very light and flexible. I think it's a great on the go cable.
NiceHCK LightLove: This is definitely the most resolving cable I've heard so far. It is completely neutral across the board with great resolution and a lil extra snap to dynamics. Enjoying it 👍
NiceHCK GreenMood should be waiting in the mailbox when I get home from work...
Apr 15, 2024 at 12:58 PM Post #9,116 of 9,241
Apr 15, 2024 at 2:02 PM Post #9,118 of 9,241
I know this thread is mostly about IEM cables but I'm looing for RCA and XLR cables, my budget would be 20 - 50 euros / cable.
https://www.aliexpress.us/item/2251..._id=20240415105835651204836108800008192799_15
https://www.aliexpress.us/item/3256...id=2024041511011013129039302810150008501323_2
Aliexpress is your friend. I dont own any of these but If you search for what your looking for. I bet you will find a few you will like. Try searching aliexpress.
Apr 15, 2024 at 2:04 PM Post #9,119 of 9,241
I kinda wish there was a thread like this on interconnects as well. Most of the cables I have are Mogami and Canare. After hearing the quality of some of these AE iem cables, I've thought about trying some of the RCA and XLR cables on AE from brands like SKW, TODN, ATaudio, Erumpent and a few others to see if they're much of an improvement.
Apr 15, 2024 at 2:11 PM Post #9,120 of 9,241
Try this thread. https://www.head-fi.org/threads/aliexpress-cables.963919/ Folks on this thread might be able to help you more.
