zmd
- Aug 2, 2009
Jude compared the two (HD25 and DT-1350) and overall, the DTs sound a bit better, clamp less (might be good or bad for you) but have smaller pads, but the HDs are cheaper and lighter, and the sound difference might not be worth your money. That's what I remember right now, at least. See for yourself here.
The thing with the HD25s is that they're meant to hold on tightly to your ears, in order to provide isolation. Most people don't mind trading off a bit of comfort for isolation. Again, it all depends on what you really need. Maybe you should look further if you value comfort more than isolation or portability.
