- Dec 23, 2014
Honestly headphone extension cables are going to look pretty much the same. Like I said, I'm not sure what else you really expect here. Cheap/junky cables ("I bought this for $3 on ebay" kind of stuff) *can* cause problems, but this doesn't mean all cables of a given type, or all adapters of a given type, etc will cause problems. Adapters are not, inherently, problematic. But junky ones *can* be. Same goes for extension cables and so forth. You mentioned Monoprice and Hosa in your first post - IME neither is a consistently reliable or quality manufacturer (Monoprice ultimately has a 100% failure rate IME, Hosa is slightly less bad) - but lumping Grado, Ultrasone, etc into the same boat with them "because they look like the same thing" is like saying a Cadillac will behave just like a Kia "because they look like the same thing."
And note that I'm not trying to force you into any specific choice - do whatever you want - I'm just trying to address what I see as misconceptions or over-broad generalizations.
No worries, I understand. Actually, I've had very good luck with Monoprice except for the headphone cables. Maybe I'll try the Ultrasone.
