MIKELAP
If they are not good it's ok i will turn them like these.
Burn baby burn!
Very nice! I didn't know you have a tube tester OK i'am moving to Montreal LOL. Thank you for the offer!
Will i was in luck that i found a guy that have a tube tester but on the other hand my tubes were tested shorted and low.
I should test them as soon as i got them but instead put them away and forgot about them now i a can't returned it.
It sure be nice to have tube tester.Weird that one side of the tube is shorted and the other is not but it tested low.Thanks!
And if only one side is low, the sound of one channel might be slightly lower than the other. The effect on the sound may well be subtle and somewhat hard to hear. But perhaps you could hear it if you were able to compare the unbalanced tube with another identical tube whose sections are more closely balanced....
Hi,
Yesterday I was using my 6080s planning to do a comparison test with the 6832, 7963 and 5687 tubes. As you may recall my fans draw air away from the amp. Suddenly I smelled a whiff of acrid smell. Mindful of all the warnings from Gibosi and TD about running 2.5A tubes I immediately shut off my Little Dot and the rest of the system. The faint smell went away, and I switched the 6080s for 6SN7 tubes.
Plugged in everything - all is OK, but I decided against taking a chance of running 6AS7/6080 tubes again in the LD MKIII. Problem is that I love the sound of these tubes - the bass is so much better. The 6SN7 tubes are OK, but they lack the heft and authority of their big brothers.
So what is the next step? Should I try the 5687 tubes as power tubes? Will they have enough power to give me the bass I like? Would they be an improvement over the 6SN7s? In addition, I would have to buy two special adapters.
Or should I go the way of the other members on this forum who bought other amps? I think I know what I want: An amp that uses 6080/6AS7 tubes or similar as power tubes, and uses dual triodes as drivers. It has to be able to be used as a pre-amp as well as headphone amp. In addition, I want a protective circuit that allows me to use a DC coupled amp. (My old Sony ss amp has a protective circuit, but I can't use my Outlaw RR2150 receiver.)
Little Dot makes a model that seems to have the specs I want - the MK9. However, I cannot find much of reviews or user information on this amp, and it seems that there is no English manual for it yet. Does anybody have any information?
I am open to suggestions for an upgrade, but I am not ready to build something myself. I realize that I could get whatever I want if you spend enough, but I am looking for the biggest bang for the buck (the LD MKIII certainly fits this criterion).
The MK9 is around $500. It seems to me that some of the amps mentioned here like the Glenn and the Woo 2 are much more expensive, and the Crack is DIY.
Any advice is appreciated.
Hi,
