Good - I see that you haven't yet been bitten by the tube rolling bug! It is very dangerous and results in buying more and more tubes - it never ends. In any event, when I owned the LD MKIII the EI tubes were among the top performers.
30-50 hours of burn in is normal, but some tubes can take much longer. I remember reading that the Voskhod tubes need 120 hours to sound their best.
This thread looks DEAD, but i will try, Mark 3 vs Mark 2 which is a better sounding amp ?, This thread has 227 pages, the Mark 2 has 888, is that any indication ?
It really depends on the Impedance of the headphones. The II will work best with low impedance cans, and the III was voiced with Senheisser HD-600/650 headphones. What do you use?
I have Hd 6xx 650s................................................. im thinking from what i have read are good tubes Sovtek 6H30-PI power tubes ?.................................Your correct i see 17 lurkers now, so its aliveeeeeee. One other question are there any good mods to do to this amp that make a good difference ?
Then you should get a MkIII OR you could upgrade your cable to balanced one and buy Mk VII SE. I an in Ontario, Canada and going to bed. Talk later. Get in touch. My email is, Tvrguy@gmail.com
As I recall you cannot use 6SN7 tubes as drivers in the Little Dot MKIII because they draw 0.6A each and the combined 1.2A exceeds the allowable current draw for drivers in the LD MKIII.
Yes, This has been done by a number of people. Go to page 223 in this forum and you will find the fellow who posted this phot. The adapters are available on eBay and Amazon.
With all due respect, RaynFox asked about the compatibility of 6SN7 as driver tubes - IMHO it will not work. As power tubes the 6SN7 work fine with adapters.
Hi mordy hope your doing ok , back then i had made an adapter for a single 6SN7 as driver tube with this schematic .Adapter is the black one top right.
I still have these, 2 of these adapters are for use with 6DJ8 tubes and other for a 6SN7 or 6SL7 tubes , but i sold Littledot MK3 several years ago ,problem is that shipping is rather expensive and i could not test adapter before shipping .To get more infos on adapters we made back then best bet is to go to https://www.head-fi.org/threads/little-dot-tube-amps-vacuum-tube-rolling-guide.563884/
