If I bought an MK6,
The tube type is actually an ideal choice for me,
and I definitely would have spent more money to get those great tubes.
I bought the MK8 instead since I had an HD800.
I almost never heard a better tube amp for the hd800.
Using 6h30dr Supertubes was not cheaper either.
Yet now I settled on rolling tubes to a 6n6p (at higher bias) which is quite inexpensive which save me a ton money,
and actually more holographic than the expensive Supertubes I still have.
Since the MK8 is set for higher impedance cans, I needed to lower it for my choice of planar cans.
The output impedance switch mod testing solved that Problem.
Since I didn't install the switch yet,
I currently have the amp I one setting to match a 20ohm can, since my best headphone is the HEKV2.
So, my point is, I went for the more expensive amp, which turns out using cheaper tubes than MK6..
Yet if I knew what I know now, I would have choosen the MK6,
Both for my power needs with planar heaphones,
And for the magic of the output tube choice (WE tubs).
I am guessing my MK8, in its current tube choice,
is less tube sounding and definitely less powerful than MK6,
but enough juice for my HEKV2.
Yet for either MK6 & MK8 amp, I am strongly convinced on using same driver tubes.
The 6C8G tubes with adapters. ( a 6sL7 equivalent type).
Since the 6C8G have more gain (mu), I get close to the fabled ECC35 type I also have.
The 6sn7 types weren't as lively in comparison,
since they played better with higher bias.
Yet the best one was the Silvania 6sn7W.
Since the driver stage for the MK8 is almost identical, I am convinced this applies to both, regardless of the powerube stage.
On the MK8, I tried literally every 9pin driver tube possible, regardless of spec.
The best were the tall e80cc pinch, yet for all the 9pin tubes,
Literally No 9pin, not even one, could beat the best 8pin tubes.
Most probably because of this the amp design.
It was actually a great thing for me to be able to try all types of 8pin types, and I rolled so many different types.
Then one day I put in a different type with a bad adapter.
I fell asleep before I could test and left the amp on...
Long story short,
I end up waiting a dam long time over a month for a replacement Transformer,
as my driver tube "heater winding" was burned.
That put a halt to my modding ,
And left me pretty sore about Little Dot customer service.
I lost my motivation after that.
I recently got my motivation back with the tiny cute tube amp I use for headphone break in.
It all tubes:
http://www.head-fi.org/t/780178/any-opinions-reviews-on-gemtune-appj-pa1502a/260_20#post_13145720
This tiny amp is a jewel in that it is running class a triode mode,
And has Japan output transformers, and implement a modern PSU design to the tubes with Constant Current, and DC heaters.
