WilliamLeonhart
Ordering straight from Burson is the best route to go. Even for a country where shipping from oversea would typically be a pain in the as2 like mine (VN).
I'm the new guy... My LD I+ is in the mail. I also ordered some EI 6HM5 tubes. I wanted to verify what family this tube belongs to. I've seen it mentioned as being an EF95 and also an EF86...
Anyone know definitively which it is? Mostly I am wondering how tI'll need to set the jumpers when I roll the tubes.
Thanks!
much obliged gibosi!
I think the most damage to the wallet is done in the window of time a new toy is ordered to when you take delivery. It is in this window where I am obsessed with researching accessories, mods, tips and tricks, etc. Once I have the item in hand, I usually calm down and just enjoy it. Delivery can't happen soon enough!
That being said... I'm looking for an op amp now. I want to get my LD I+ as tubey as possible (I know it is not a true tube amp). I am not really interested in critical listening. I want pleasant highs thick syrupy mids and strong bass. Would still like detail and immersive soundstage, though, these are down the pecking order a little. Which op amps are more in line with this request?
So far, the main contender for a new op amp is the Muses02... really based on one post about it being very lush and open and not for those wanting a neutral, critical listening option. True to your experience?
I'm going to buy an op amp, can't be helped. So help me make a good choice.
Thanks!
Thanks again gibosi, sounds great to me. And peter123, I'm not afraid of the warmth! Thanks for the info, helps. The only description on the burson I've seen outside of "sounds great" is that it's brighter. That always kind of scares me as I'm not into bright. I'll probably get the muses02 now since it seems the most appealing and after I've had a month or so to digest that, I'll get the burson and see for myself.
Great info, thanks
No worries. The Burson is not bright per se but just in comparison. I'd actually rather say clear than bright. Since the LD I+ is also equipped with tubes that can also be used to tune the sound I'm sure either one will be great after some tube rolling.
Good luck and enjoy the music
Were you able to compare the Burson to the MUSES01?
Yes, I think it's safe to say that all of these options will be great sounding options... It's just which sounds best to you????? I like to change one thing at a time. So, I'll replace the tubes first with the 6HM5' that are in the mail. Then I'll try the mullard 8100 and see which floats my boat. Maybe an RCA 5654 black plate too. Then, when I've got the sound I want... I'll mess it all up by introducing the muses02 with each tube. So, I should get to the Burson in about 6 months! Maybe I'll just skip to the muses02 right off.
