kazcou
- Mar 11, 2012
For those who are looking for one : http://www.buychina.com/items/margaret-dac60-fever-dac-audio-decoder-decoder-decoder-hifi-yxpwnlljli
I think a bad translation. On the photos, you can see it is a LITE.
Nice find - wonder which PCM1704 they are using. Bet not a U-K
I think it usesDF1704.
http://www.fetaudio.com/archives/186
I changed out the clock as well to a battery powered Crystek 957 on the Dac60. I don't know if it is possible for a dac to get any better. LOL
How did you find a 6.144Mhz 957? I used the Vanguard to good effect.
You're these are so good - esp with better coupling caps and NOS tubes. Just that nobody can find one anymore.
Here is another DAC that uses the 6922 - but with tube rectification - very sweet!
http://www.musicalparadise.ca/store/index.php?route=product/product&product_id=80
Audio-GD has a JZ clock board that has 1/4 fs out. I replaced the generic clock on it with the Crystek
I see - contacted them and they said they didn't sell it anymore.
I have one from China - but just went with the Vanguard. Have you done any other mods?
It has been about 2 years since I bought the JZ clock board from Audio-GD. You could use 2 flip flops to divide by 4 but it will involve a bit of work to wire it up. The circuit is simple though. If you power it from a battery it will make things very easy.
I have clock divider board from China - it will do 1/4, 1/2, full - with a TXCO on it. I had as a back burner project to swap that out for a 957 and install. But my case has no room left. The M-Lytic, Hammond Choke and those huge M/S S/G/O caps fill it up.
Cheers
I had to mount the clock on the outside of the case but the battery I was able to fit inside since it was long and flat. I just used zip ties for the clock on the backside and ran wires to a switch that I mounted to the side using industrial double sided tape. It doesn't look pretty but is very functional and was a quick job.
Perhaps you can help me with something on another topic. I actually have more time at work to listen to music then at home so I have had a pretty good desktop system that consists of some 4" Fostex full range speakers, Olasonic cd player, Olasonic dac, Oppo HA1, Wyrd USB cleaner, and a parasound Zamp. I've been using this system in one configuration or another and would want a change. In my current configuration, I am using the balanced out on the HA1 to power the Fostex speakers.
I am looking for mini 4" speakers (nothing bigger as I can only listen at low volumes and desk space) and a small pure class A amp (2-10wpc). I was looking at the monitor audio radius 90 speakers as a replacement. Any ideas or recommendations would be appreciated.
