castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
I'm used to set my volume by going over foobar's volume toolbar and scroll(MOUSE3). by default it's a 1db increment and I find it great to fine tune volume instead of moving the volume slider itself.
adding columns UI (I need it for other components) is now limiting the volume to 6 steps from zero to max when I turn the mouse wheel.
so my problem is that it does not follow what I set in preferences->advanced->playback->volume step. and simply going back to default UI gives me back my 1db volume increment (or whatever I set).
is there and easy way to get it to work like I want with a lot more steps?
thank you.
thank you.
