bassboysam
- Jan 24, 2010
Does anyone know why when I connect my pro-ject switch box to the LD III I get no sound from the pre-amp out on the LD?
The headphone out works fine with the switch box. Also if I connect the source directly into the LD everything works fine. Am I missing something here? It seems that the headphone out works when the input is phono or line level, but the line out only works if the input is also line level. Does that make sense? Do I need a phono stage between the switch box and the LD?
Thanks
Thanks
