Golden Monkey
- Apr 5, 2008
I've noticed a few posts where people have used a Little Dot III or IV as a preamp for their MKV. Just looking for a bit more detail on the experience now. How do the 3's or 4's perform as a preamp for the V? Have you tried doing it the other way around (MKV as pre for the tube amps, and if so why or why not?).
Curious as well on how you ontrol the volume overall...do you set the preamp at a certain level, and control your outpt volume through the MKV, or crank up the MKV and control it through the preamp?
Any recommendations between the III, IV, and IVse? Is the overall gain in sound quality worth the expense, or is it more worth it to have the versatility of a tube and SS amp?
Thanks folks....
Thanks folks....
