Tronsmart Official
Member of the Trade: Tronsmart
Your flight journey would be wonderful if you won't be bothered by the big noise; your way to work would be easy if you enjoy the best music; your walking time would be more fun if you get enough peace. Thus, a good active noise cancelling earphones will meet all your needs.
There are a lot of active noise cancelling headphones, but it's not quite comfortable when you walk under the strong sunlight. A good ANC TWS earphone will be the best choice. But most active noise canceling earphones can only reduce noise up to 25-28dB on low frequency. It doesn't work well if the noise is louder. And most of them use only Feedforward ANC, or Feedback ANC, which can only reduce either narrow range or wide range noise. However, they still cannot provide better experience.
To solve all the issues of customers, Tronsmart launched the hybrid active noise cancelling earbuds Apollo Bold, equipped with Qualcomm QCC5124 chip. It can reduce noise up to 35dB from full frequency, and with the hybrid noise cancelling (both Feedforward ANC and Feedback ANC), it can reduce narrow and wide range noise, meaning whatever noise it is. Plus, it also uses True Wireless Stereo Plus technology, which allows both left and right earbuds to receive the signal from the mobile without any delay.
Do you want to have a try? We will have a Giveaway during July 15-July 31! Don't miss the chance!
More details, please check: https://bit.ly/2W5faYB
For Giveaway, please visit: https://bit.ly/3gTTyXi
