Syzygies
- Nov 16, 2004
Would it be easier to assemble a project using many surface mount components, if we could clamp a laser-cut frame over the PCB, drop in the components like a kid filling in a wooden puzzle of the fifty states, solder, and remove the frame?
"Caching" and "Precomputing" are key concepts for computers. We can't all afford $100,000 robotic assembly machines, this would be like precomputing the benefits of having such a machine, for easy distribution for home DIY use.
I'm thinking that each cutout would be shaped to keep the component from wiggling around, while at the same time providing openings to reach in to solder. The frame would be no thicker than necessary, with a legend to help remember what goes where.
A variant would be to have the holes fit the parts closely, and dab in some kind of glue as scaffolding that wouldn't hurt the component, solder, or operator.
I've noticed various references to laser cutting here, and also to a general distaste for surface mount soldering. Doobooloo's laser cut case blew me away, and she ran the job herself at school. A mostly surface mount PIMETA using discrete diamond buffers would beg for some kind of hand assembly assist like I'm proposing.
