FiiO-Shadow
Sponsor: FiiO
- Sep 4, 2013
Hi, Skullbox.
The FW1.44beta already does not have the OTG function.
Hi, JWolf.
The above steps are also difficult for you to change the font size?
We may release the firmware FW1.45beta with bigger font later.
Hi, JWolf.
The reason I ask for the 1.45beta is that others might have difficulty doing the modification and 1.44beta is useless because once the latest DAC USB drive is installed, 1.44beta won;t work with it. So 1.45beta also needs to be put out there.
Can anyone tell me the difference between 1.44 beta and 1.45? And does 1.61 beta re-introduce the search option?
Link to the post that mentions the X3II 1.61beta please. Thanks.
The 1.44beta and the 1.45beta are different in that the EQ did not work at all in the 1.44beta were it sort of works in the 1.45beta. Also, the 1.45beta uses the a much newer USB DAC driver (for Windows) that is signed. The search in both the 1.44beta and the 1.45 beta are broken when you try to search by track as it searches by filename and not the track tag.
Misread Apologies, it was the X1 1.61 beta. I take it that the FW1.6 for the X3ii doesn't have the search option?
can the volume number still at small (default size) , but the rest is large? because when using the large version, the volume number position is not aligned.. looks cheap... but the large font on file selection, setting, etc. is very good |
I really like the Large Font version of the beta firmware.. but i dont like the topbar font being too big.. ruins the placement...
FOR X3 II
so i made the edit for this,
- Using 1.45Beta
- Top Bar is Normal Size Fonts, same as default firmware size
- The Rest is Large Font.
- Make the English menu better (to me ), and fixed the uppercase, e.g. Play mode -> Play Mode, also make changes some menu text, Play Setting -> Option , System Setting -> Setting, and many text editted. (english only)
if you want to try, just update with this file
https://dl.dropboxusercontent.com/u/21932186/FIIO%20X3/X3II-1.45b-BIGFONT-NormarTopBar-EditText.rar
