alvin sawdust
Did you receive the EF800s phiero?
If so, how are you getting along with them?
Okay... Another update.
Finally got the RCA 6080s, the GE 6AC7s, and obviously, the ones I already had (the GEC Brown Base 6AS7G + Telefunken EF80 + Stock Tubes + a Variety of 6SJ7s)
Best combos as follows:
#1 - NOS GEC Brown Base 6AS7G + NOS Telefunken EF80 - Smooth, Balanced and rich sound. Nothing is too sharp or too loud. Perfect for rock, classical, and good for all kinds in general etc.
#2 - NOS GEC Brown Base 6AS7G + NOS GE 6AC7s - A bit less top end, but still almost as good as the Telefunken combo.
#3 - RCA 6080 + NOS Telefunken EF80 - Sharper, crisper sound, with very tight response. Closer to a high powered solid state, but a bit thin on the bottom end. Good for Techno, Electronica, Pop.
#10 - Stock tubes - Work fine...but don't expect much from these. There really is a massive amount of improvement to be had from tuberolling the 339.
More tube impressions coming soon as shippings roll in. Getting some Russian tubes, and some RCA 6AS7s.
Received the 339 from Juking 2 days ago (took about a week to arrive after ordering) and presently doing break-in. Initial impression—with stock tubes—is that this amp is remarkable in both power and overall sound. My HD-800 and HD-600 sound like a perfect match for the 339. The DV 3322, as good as it is, is the junior varsity in comparison to this guy.
I plan to change to better tubes after this week and also to try a couple of more substantial power cables.
Forgive the childishness but all I can say at the moment is “Wow.” Thank you, La Figaro.
