May 22, 2024 at 5:00 AM Post #64,142 of 64,373
A little update
KZ C56R
KZ GR
KZ RX
KZ IE80
KZ DT5
KZ ATE
KZ ATES
KZ ZST
KZ ZST Pro
KZ ZST X
KZ ZSA
KZ ZSE
KZ ZS1
KZ ZS3
KZ ZS3E
KZ ZS5 V1/V2/V3
KZ ZS6 V1/V2
KZ ZS7
KZ ZS10
KZ ZS10 Pro
KZ ZS10 Pro X
KZ ZS10 PRO 2
KZ ZSR
KZ ES3
KZ ES4
KZ ED3
KZ ED3 Youth
KZ S3
KZ ED9
KZ ED4
KZ ED10
KZ ED11
KZ ED2/EDR2
KZ HDS1
KZ HDS2
KZ HDS3
KZ ED16
KZ EDX
KZ EDX Pro
KZ EDX Pro X
KZ EDX Ultra
KZ EDXS
KZ AS06
KZ AS10
KZ AS12
KZ AS16
KZ AS16 Pro/Highimp
KZ AS16 Pro X
KZ AS24
KZ BA10
KZ AST
KZ ASF
KZ ASX
KZ ZAS
KZ ZAR
KZ ZNA
KZ ZSN
KZ ZSN Pro
KZ ZSN Pro X
KZ ZSN Pro 2
KZ ZSX Terminator
KZ ZAX
KZ ZAT
KZ ZS4
KZ ESX
KZ Lyra
KZ EDC
KZ EDC X
KZ EDA Bundle (Bass, Balanced, HiFi)
KZ EDX Lite
KZ ZEX
KZ ZEX Pro
KZ ZES
KZ PR1 Normal/HIFI
KZ PR1 Pro
KZ PR2 V1/V2
KZ PR3
KZ DQ6
KZ DQ6S
KZ DQS
KZ D-Fi
KZ EDS
KZ Ling Long
KZ ZVX
KZ Krila
KZ Castor Harman/Bass
KZ Symphony
KZ x AngelEars Collab Libra Balanced/Hi-res
KZ Merga
KZ Vader - Balanced/Hi-res
C04 / 1BA+1DD
C10 / 4BA+1DD
C10 Pro / 4BA+1DD
C16 / 8BA
C12 / 5BA+1DD
CCA A10 / 5BA
CA02 / 1DD
CA4 / 1BA+1DD
CA10 / 5BA
CA16 / 7BA+1DD
CA16 Pro / 8BA
CA24 /12BA
CS16 / 8BA
CRA / 1DD
CRA+ / 1DD
CRA PRO /1DD
CST / 1DD
CSN / 1BA+1DD
CKX / 6BA+1DD
CS16 / 8BA
HM20 / 7BA+1DD
NRA / DD+EST
PLA13 / 13.2 Planar
LYRA / 1DD
CXS / 1DD
FLA / 1DD
DUO / 2DD
PIANIST / 2BA+1DD
POLARIS / 1DD
RHAPSODY / 4BA+2DD
TRIO /3DD
HYDRO /8BA+2DD
May 22, 2024 at 11:15 AM Post #64,144 of 64,373
A little update
Nice! That's very interesting to see the progression listed out like that. I have only succumbed to 4 pair of KZ and 3 pair of CCA, with 1 KZ in the mail. Less than 10 pairs! So many of you here have 30-40+. :-o
that all?
right?! lol
Castor Harman's have cleared customs. Hopefully they arrive in a few days so I'm retraining my psycho-acoustics against my last working DD set, the CRAs. Currently listening to Amazon's Ultra HD service with the Hellfire PowerDAC 2.1 lighting up my humble CRA's over a balanced cable at full 24bit @ 44 kHz full send FLAC on a downloaded track.
After sleeping on these for so long (literally, these are my nightstand pair), I'm still rediscovering how good of a voice these actually have when scaled up a bit. No funny business here in the timbre when rendering flutes and strings and horns. I am, of course, cheating ... juuuuust a tiny boost at 416 and 770 hz to thicken up the bottom mids, then some help at 11.5 and 15 kHz to open up the stage and air. The veil lifts and the instruments sing through in a fluid and dreamy lean back experience.
The CRA Pros and PR3 are calling out to me but I'm not in any hurry.
link: https://music.amazon.fr/albums/B0CX258SQW?trackAsin=B0CX26NX5F&ref=dm_sh_c55d-47e6-4bef-b9fc-cbfc2
A follow-on video to my post the other day about how loud 0.05 watts is for IEM. How loud is 1 watt per channel for floor speakers? Pearl Acoustics is a good channel for body-fi content. Of course, if you want to drive yourself absolutely mad, DO NOT start investigating folded horn loudspeakers. And if you don't want a divorce, don't start building your own.
May 22, 2024 at 12:38 PM Post #64,145 of 64,373
Nowadays I have only few selected KZ Pokemons catched.
KZ: BA10, Castor Bass, D-Fi, DQ6S, Edx Pro X, ZVX, Ling long
CCA: Trio, HM20, CRA, Polaris.
Just 11.
Maybe in future I'm going to catch CCA Hydro. But do I need it? I don't know. I like this cheap ones.
May 22, 2024 at 12:42 PM Post #64,146 of 64,373
Just 11.
Nobody here in this forum "needs" more IEMs.
But we buy more and more. Almost all guys secretly hide the packages from their wifes.
Why do we do this?
Because it's bloody fun!
May 22, 2024 at 12:51 PM Post #64,147 of 64,373
Why do we do this?
I would prefer KZ to provide low-cost iems with higher and higher quality, because in my opinion iems should not be too expensive.
May 22, 2024 at 1:06 PM Post #64,149 of 64,373
Haha yeah, for now I'm content switching between ZVX, PR3 and AS16 Pro, with the rest of my iems sitting in a box until who knows when(maybe until I'm too deaf to hear whatever I didn't like in them), but I'm certain I'm gonna get another one eventually. After all, I'm yet to catch a CCA pokemon
May 22, 2024 at 1:53 PM Post #64,150 of 64,373
Added a cap and a 30095 to the ZVX to improve the speed, bass impact and resolution. This is even better than CCA version. (Ok I forgot what it is called and too lazy to check) the design of the ZVX is pretty silly however if look at that unnecessarily tight tolerance of the positive pin right next to the cut opening.
Hello! I just joined so I could ask you about this. Hi-Fri mentioned in his ZVX video that it had space for a BA and I thought it would be a cool project to get started with BAs. I've retuned single DDs and planar in the past but never BAs, last time I tried a hybrid it sounded off to me and the BA timbre was whack, but this mod you've done seems cool and fun!
May I ask some questions? I see that you used a capacitor or resistor, the little brown box, did you also use damping or tubes to guide the sound to the nozzle? Also, just how competitive does it sound? Sorry if I'm not supposed to ask here or if you've already shared it but I could find no more info and I'm super curious. Thanks in advance!
May 22, 2024 at 7:16 PM Post #64,151 of 64,373
Hi, I used both a cap and a resistor. There's no space for a damper or a tube. The slot is directly connected to the front cavity of the DD so you can only electronically tune it. I dampened it to give the sound just a bit more texture and if you don't dampen it enough you will hear all the BA timbre. You can also try using a standard mesh filter paper and glue it to the BA nozzle but that will be a little tricky.
May 23, 2024 at 5:06 AM Post #64,153 of 64,373
Thank you for the reply! Got it. Glad there's passthrough between the BA slot and the front cavity. I wish the zvx driver was a tad more resolving but the bass is fun, hopefully this helps bring out more details! :)
May 23, 2024 at 6:19 AM Post #64,154 of 64,373
Definitely, and the same thing happens if your collection of over-ears start to multiply like gremlins. You settle down on 2-4 pair that are close-by and reach consistently for 1 or 2 pair, because a) switching up all the time isn't very convenient, and b) brain burn-in is a real thing and can mask the finer points of some sets until your senses re-adjust to them, like trying to enjoy caviar after having a big piece of chocolate cake.
Ah, you've yet to learn the audiophile's secret code!
"Dearest, you are the light of my life and the fire of my loin, but the context of the situation is as follows. Some men are addicted to gambling. Some men spend all their time prowling the night in the deep grips of strong drink. Yet others spend all their time at the office, traveling for work, or both. You're angry that I collect audio gear to analyze and appreciate the multifaceted sonic complexities of Dvorak, Liszt, and Rachmaninoff in all of their glory whilst responsibly sipping a cognac followed by a single origin espresso here at home. Tell me, what vice or pleasure am I to turn toward that doesn't interfere with fatherhood, leave me vulnerable to temptations of the flesh, or disrupt my good employment? Oh, and by the way, I meant to give this to you earlier - it's the latest scent from Guerlain."
May 23, 2024 at 6:21 AM Post #64,155 of 64,373
If you haven't seen it, there's also a DIY sub-section here on the forum :beerchug:
