Whazzzup
Well my old school kef 300A needs upgrading and perused various options. I don’t have speaker amp so want to use internal dac, no usb this time, wireless that can do apple play or play roon core from my antipodes music server wireless network as well. The specs seem impressive on the new Kef wireless II system, so is the price Canadian, at over 3500$, but comments have been, it’s worth every penny.
Anyways I’m tossing the thread into the ether of head fi to see if folks have this system, or compared this system, or have views on a comparable book shelf speakers at this quality level, for ease of installation, use, and sound quality.
What's New
Owners of the LS50 Wireless may be wondering what’s new? The answer: pretty much everything. The original was fantastic, but LS50 Wireless II is better in every respect, with improved sound, better connectivity and usability.
So any thoughts, comments, pictures, whatever in the desktop / computer/ wireless speaker solution appreciated, possibly an unofficial LS50 Wireless II reference point and sounding board?
Model | LS50 Wireless II |
Drive Units | Uni-Q Driver Array: LF: 130 mm (5.25 in.) aluminium cone HF: 25 mm (1 in.) vented aluminium dome with Metamaterial Absorption Technology |
Frequency range (-6dB) measured at 85dB/1m | 40 Hz – 47 kHz *Depends on EQ settings |
Frequency response (±3dB) measured at 85dB/1m | 45 Hz – 28 kHz *Depends on EQ settings |
Amplifier output power (per speaker) | LF: 280W HF: 100W |
Wireless streaming features | AirPlay 2 Google Chromecast ROON Ready UPnP Compatible Bluetooth 4.2 |
Streaming services | Spotify via Spotify Connect Tidal Amazon Music Qobuz Deezer QQ Music via QPlay Internet Radio Podcast |
Source resolution | Network up to 384kHz/24bit Optical up to 96kHz/24bit Coaxial up to 192kHz/24bit HDMI up to 192kHz/24bit |
Interspeaker connection | Wireless: all sources resampled to 96kHz/24bit PCM Wired: all sources resampled to 192kHz/24bit PCM |
Supported format (all inputs) | MP3, M4A, AAC, FLAC, WAV, AIFF, ALAC, WMA, LPCM and Ogg Vorbis |
Supported format (network) | MQA DSF: DSD64, DSD128, DSD256 DFF: DSD64 |
Dimensions (HWD per speaker) | 305 x 200 x 311 mm (12 x 7.9 x 12.2 in.) |
Weight (per set) | 20.1kg (44.31lbs) |
Power input | 100 – 240VAC 50/60Hz |
Power consumption | 200W (operating power) <2.0W (standby power) |
Primary speaker Inputs | HDMI eARC TOSLINK Optical Digital Coaxial Analog 3.5mm Auxiliary USB Type A (service) RJ45 Ethernet (network) RJ45 Ethernet (interspeaker) |
Output | RCA Subwoofer output |
Wi-Fi network standard | Dual-band 2.4 GHz / 5 GHz |
Secondary speaker Inputs | USB Type A (service) RJ45 Ethernet (interspeaker) |
What's New
