chaotic_angel
I will not argue on this hahaha
I assumed its more detail on SS mode then tube mode? Same soundstage on both modes?So far I like how the tube sounds... really relax vocal and smooth treble (yes there is treble)...
Not Thumping Bass etc...
Pair with VO, really synergy for my taste....
Yes u get it right... More detail and wider soundstage on SS.I assumed its more detail on SS mode then tube mode? Same soundstage on both modes?
Does tube mode bypass the opamps too? If so, sounds like you need to roll opamps for SS mode to your liking.Yes u get it right... More detail and wider soundstage on SS.
on tube can consider intimate, yet no overlay sounds, the separations still there. Better vocal will be the high light
tbh SS sounds regular or ordinary for me... well it supposed to be like MUSE02 sounding, dont get me wrong, its great, but not something WOW for me.
the Tube is different story.. well probably I am just in for the tonality then the technicality .. IMO
btw, PSU is a must for me.. using TAP-1 without it.. better I used DX300 alone..
same question I asked to the maker of TAP1, still no answer yetDoes tube mode bypass the opamps too? If so, sounds like you need to roll opamps for SS mode to your liking.
Yes, it could have been a different discrete topology for both modes.same question I asked to the maker of TAP1, still no answer yet
All i received was inside there are 2 PCBs, what are they for? still don't know.Yes, it could have been a different discrete topology for both modes.
Hmm.. good questions... Franky speaking I also dunno.Does tube mode bypass the opamps too? If so, sounds like you need to roll opamps for SS mode to your liking.
I think only way to test out is having the opamps rolled. If the tube mode retain the same signature from rolling then its different.Hmm.. good questions... Franky speaking I also dunno.
I thought of that, not taking the risk!Simple way is to remove the MUSE opamp, check if the tube still make a sound.. Although there's slight risk of doing this..
Well valid point.. anyway, I like the tube sounding.. so probably just enjoy that..I thought of that, not taking the risk!
Ok, i bought 2 X Oracle ll opamps intended for Xduoo XD05Bal, i will roll them both in TAP-1 instead and hear the outcome.Well valid point.. anyway, I like the tube sounding.. so probably just enjoy that..
Since it was for my Headphone, so it will stationer next to my desktop set up..
hahahah.... but I am looking forward to know the fact..
looking forward for that...Ok, i bought 2 X Oracle ll opamps intended for Xduoo XD05Bal, i will roll them both in TAP-1 instead and hear the outcome.
