Patrick82
Banned
- Mar 1, 2003
For the past month I have been running music through the K1000 at 22 dB lower volume than I listen to. Today I paused the music (everything still powered up) for 4 hours, and when I resumed playback it sounded MUCH brighter! I didn't have any problem whatsoever with brightness before that, it sounded warm and like real life! But now it sounds fatiguing and I get a headache from the edgy treble, there's also lack of bass. It's unbearable to listen to, annoying sibilance.
It's not the source that's the problem because I use two with the other in stand-by, it's either GCC-100 amp, Valkyrja speaker cable, or K1000. I believe it's the headphones that require constant diaphragm movement to keep them soft, what do you think?
