I just received the Meelec tri flange tips, that someone had mentioned earlier in this thread. I had been using Meelec double flange tips prior to these, and I thought they sounded very nice, more balanced that the other plethora of tips that I had tried. I still had to EQ the low end down a couple of db's with the double flange tips. Also, I was using shallow insertion with the double flange tips, because if they were inserted too far, the sub bass/bass overwhelmed the rest of the sound spectrum. Now for me the tri flange tips sound much better, sub bass/bass is there when called for, but does not overwhelm the rest of the sound......they also stay in place a lot better with fairly shallow insertion. I have no need to EQ the bass down with the tri flange, and they don't fall out when moving around. I am also getting a wider/bigger soundstage with the tri flange tips vs all of the other tips that I tried. I also tried the tri flange tips on my FXD80, with similar results, the sub bass/bass on them is reduced enough for them to be more enjoyable to me, more balanced sounding as well, same comfort and stable! The Meelec tri flange white/clear silicone tips would be something to try for those that would like a more balanced sub bass/bass to mids and highs, with a wider/bigger soundstage, and a nice fit!
