FCJ
Propz go out to his homeez at Burrz-Brownz!
- Jan 30, 2002
A few weeks ago I asked JMT to build me an interconnect for use with my nOrh SE-9 and Philips 963 SA SACD player. I've been using it for a few days now, and it's great.
JMT's cable is made from Homegrown DIVA Braid; the RCA plugs are Homegrown rhodium/silver plated connectors. They are very flexible and fit the nOrh/Philips snugly.
Compared to the three cables that I know (Kimber PBJ, Outlaws, DiMarzio 1 meter interconnects), the "JMT cable" (as I'll call it) excells in two areas--detail and soundstage. I use the nOrh/Philips with the AKG K-1000s, and I've found detail to be slightly increased with the JMT cable compared to the others. The real benefit is that the increase in detail is never at the expense of added hardness or perceived brightness (and yes, I will agree, that the AKGs can be a bit bright, especially after a lengthly listen).
Also, as I mentioned soundstage (the real strength of the AKGs, IMO) appears to be even wider with the JMT cable than before. It's sometimes scary how the music can almost "sneak up" on you, causing your head to turn to see where it's coming from. This sensation has increased by a fairly wide margin with the JMT cable.
Again, overall I've only been using it a short while, so my impressions could change over time. However, I expect the improvements in detail and soundstage to only get better over time. To my ears, at least, JMT has a winner with his interconnect.
Now when is he going to design a headphone?
