- Jan 6, 2010
Anybody know how to remove the foot pads? I guess it's where the screw at? I plan to send to somebody to add in some components in order to utilize the big volume knob to control DAC volume passively, is that even possible?
Anything is possible! JDS Labs can perform such a mod, and I suspect we're better suited to do so.
Simpler idea: Why not connect your equipment to the 1/4" output jack? Unity gain (1.0x) will gave the exact function you've described.
You'll need strong fingernails to pry the feet off.
