Well, it was.
It wasn't software or settings. How do I know you may ask? Because I bought another jcat usb xe card and it doesn't do that. Granted I'm also using a different power supply now.
So, I'd like to give some impressions with the Jcat USB XE and Net XE cards. My pc system never sounded this natural before. Absolutely annihilated digital harshness and edge, and everything sounds exceedingly organic and lifelike. But it wasn't easy to get there. I had both cards connected to my uptone js-2 at one point, but the sound thinned out and the unit got extremely hot. I had ordered a Jcat optimo 3 duo and while it was able to keep it's sonic integrity while powering both cards, I missed the sweet and nimble tone of the js-2. The jcat 3 duo provided great body and density while also providing almost fatiguing levels of bass, I preferred the tone of the js-2 and the density of the 3 duo. So I wondered how it would sound if I connected the JS-2 to the usb xe card and the 3 duo to the net xe card, and I'm pleased to say, I got the best of both worlds. The full body of the 3 duo and the sweet vocal tones from the js-2 came through. I'm not of the opinion of throwing more money to fix a problem, but I have to admit it did work out in this case. Absolutely the best my system ever sounded. The level of upgrade is comparable to me upgrading my dac from a Musician Pegasus to the Holo May. But if you add up the cost of the two power supplies plus the two jcat cards, it gets pretty close to a holo may in price. I know purchasing another dedicated power supply when you can use one may seem excessive, but it was absolutely worth it in my case. I'm just so impressed with the way it sounds, I thought I should share it with you all.
