wrathzombie
- Aug 16, 2011
Recently, i have noticed a problem with my Maverick Audio A1 amp. I have plugged through my HRT streamer to my laptop. I also have Cambridge audio S30 bookshelf speakers attached to them.
The problem is that when I move the volume dial, i hear a distinct screech on the right speaker and it turns of completely. Moving the dial carefully, with a lot of adjustment makes the speaker work though.
I was wondering if there was something I could do to fix it.
The volume potentiometer should be cleaned with "Pot Cleaning Cap" or similar product.
Edit : Radio shack tuner cleaner is maybe more easy to find.
wrathzombie
- Aug 16, 2011
Cool. Thank you..
Cool. Thank you..
wrathzombie
- Aug 16, 2011
I am in India and DeOxit is not available here. I was wondering if you could give me names of the brand or chemical composition of these products, so that I could look for substitutes..
Cool. Thank you..
This product is only to remove dust an clean up the contact surface, normally is accumulated dust you have to remove, you can try with a air compressed bottle to remove it, moving stronger the potentiometer when you blow it.
Don't know the composition, I have just used it long time ago for my musician gears (amp. effects etc...).
Edit : I hop is not an electrical problem, remove dust and you have to see a difference.
wrathzombie
- Aug 16, 2011
Thank you. I just opened it and blew air into the volume dial and the problem got solved.
Glad you have repaired your A1, it's a good device
