Sure, I could just use two 6ft USB(2.0) cables from my Nintendo Switch & PS5 straight to my DAC, and then a 6ft Optical cable from my DAC and straight to my TV for Streaming, but ideally i wanted to have my DAC(s) away from my TV stand and beside me on my End table next to my sofa, just for convenience sake and to not have to deal with a wirey mess.
Currently, I'm using a 16.4ft USB(2.0) Active/Repeater Extension cable, connected to another 10ft USB(2.0) cable from my Switch and straight to my DAC, and the same exact method from my PS5 and to my 2nd DAC. Then, a 30ft Optical cable from my OLED TV and straight to my 3rd DAC. that's a lot of DAC's.
Anyways, I've read that USB(2.0) has a 16.5ft limitation in regards to length(Although an active cable should extend upon that), while 'modern' Optical has been said to be limited to 49ft.
Am i in the clear? Or will i be getting crappier audio due to longer cable length? I don't want to sacrifice audio quality, even if that means setting it all up in my TV stand. Somebody once told me that there won't be audio degredation since both Optical and USB are digital, you'll either here pops, drop outs or they'll stop working all together. But I've also heard otherwise. Which is it?
I haven't heard a single pop, nor have i had any drop outs. I'm just curious if the Audio quality is being compromised compared to using shorter 6ft cables instead.
