elfary
- Sep 29, 2005
All we can do now is tweet ad infinitum to Tim Cook, Cue, Pschiller and fill bug reports in the hope that iPhone7 hpo gets back on track.
No FLAC support
No expandable storage
Chained to iTunes forever
About the processor noise heard through sensitive hear phones.
It's very important to test this in as quite environment as possible, with sensitive earphones, not all will pick it up. At home I can easily hear the processor noise with my AKG K3003i on my iPhone 6s Plus 128GB Gold (TSMC) bought in Sweden. I've tried the same model in a store and it exhibits the same noise. The easiest ways I've found to hear the noise is to invoke Siri and just let her idle waiting for a command, while doing so swiping up the control center and adjusting the brightness slider back and forth, then you can clearly here the buzz. It's good to know that if you don't have any thing keeping the audio output active, like playing music with volume at least one step above zero, it will cut off the output and even my AKG won't sound the noise.
I've tried with my Westone 4r and they exhibit less noise than my AKG K3003. Also my Koss Porta Pro just faintly and AKG 701 nothing or barely a hint.
And it won't have 3 cirrus chips in it...lol joking aside. If it is shielding problems....then the only way is to open her up, and re-shield her lol.
iPhone 7 will be another year before it is here
Checked with Shure SE535.
Heard exactly the buzzing noise that Lachlan videos showed. App switcher actions show it clear as light of day.
the iPhone 6 that was besides the 6s did not exhibit any noise while performing same actions.Nor my 8 months old iPhone 6 does. Never in my whole tenure have i heard any background noise that was not on the album.Actually the buzzing has been a first. Never heard it in iPhone 3Gs, iPhone 4, iPhone 4s, iPhone 5, iPhone 5s or iPhone 6. Hooray Tim Cook!
If you can not hear it power to you. If you can like i do...errr i'll pretend iPhone 6s never happened.
Bad shielding.
To me this is case closed. Wishful thinking (batches and stuff) won't change that bad shielding (As it's per design).
If you don't get tonality right, nothing else matters.
Did you ONLY hear it with the app switcher? This is the only time I can hear it. If it's only present during the app switcher changes, then I'm not convinced it's hardware/shielding. If Hardware it should happen at any stage of software navigation, including just sitting there with the music app up and on pause, with no music, while doing nothing else. Yet there is no noise in that situation. If it's only present when using the app switcher, wouldn't that be indicative of a software issue? A_rec, what do you think?
I would expect that app switching, etc. causes CPU/GPU to run faster. Just listening to music is not very taxing on the system.
