got the H2 today. The feature to listen to sd card (not bluetoothed music) while being controlled by the phone is attractive to me. H2 in my right pocket and my phone on my left. It’s surprising how inexpensive it is for what it gives.
Thank you got it working. However i have to say the dynamics are lacking a bit on the H2. I was hoping it would at least sound close to the UA3. Perhaps a FW upgrade can do some magic? A bit to digital glare no matter the filter used.
Thanks for the reply. Is there a limit of songs that can be placed on the msd card and used via symlink? I ask because i have around 10500 songs on the card and the UI on the symlink is pretty laggy at times.
What about the lag i am experiencing on the Edict Player app while using Symlink?
Edit: I must add the lag seems to go away after playing a few tracks. However i notice that there any artists and albums as unknown. I take great pains to tag all my music properly so what might be the issue?
Thanks thats very helpful. I just edited my post before you replied.
"Edit: I must add the lag seems to go away after playing a few tracks. However i notice that there any artists and albums as unknown. I take great pains to tag all my music properly so what might be the issue?" attached picture as an example
If you have any artist or album showing as unknown, you can send us sample files to check. We give all of these to our software team and once in a while they add fix for this into firmware update.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
This maybe a special case where the XMOS update to v.1.3 has done wonders for me. No glare whatsoever and though the low end is still reference it is adequately satisfying.
How do I connect this to the eddict player? I'm on the init firmware, updated app. My up5 and up4s are in there fine. It allows me to control the settings when I connect usb but it doesn't find it in bt. Am I doing something wrong.
