Nazo
- Aug 24, 2008
Hmm. I thought the Bubinga was supposed to be more ideal for mids. However, much like you, I'm probably looking for a warmer mid-range. "Slightly more mellow up top" sounds about right. It shouldn't take much at this point. Guess that does leave the little detail of it being a light density wood though. Hmm. (Well, if I can help it I'll be scraping together the money sooner rather than later, so I'm definitely thinking along these lines.)
Hmm. I would describe the Denons as being just a little bit bright themselves. To that end, a slightly dark cable seems to suit them well I thought. I would point out though that the effect is very cumulative. I ran the wires from the cups to a 6.35mm Neutrik connector and to that I can attach different cables. With the shorter Mogami cable (I'd say roughly 3ft) the sound is just about perfect, but the longer cable I made (probably closer to 10ft) for distance has a little bit too much effect I think. I've been using Canare for my other stuff and while I found it to have too harsh highs and too much bass for my tastes when directly to the Denons, I might later rig up a combo using the Canare for most of the distance and Mogami for the shorter end, lol. Wierd, but I think it might work.
Oh, and I'm using the bigger Neglex Quad, the W2534. I stripped the outer shielding and coating and used some shrink tubing to get it nice and thin versus the really thick original size, then stuck a toroid on the end with the plug. It's not quite as flexible as it should be due to the tubing being just a bit thicker than I probably should have used, but it works very well for the most part.
I may have to try that Kimber cable later on.
Exactly what my problem was and one of my biggest hopes with changing the sound signature with cups. Actually, I do want to make sure not to reduce the bass any further though. Between the Mogami cable and the stuffing, I have the bass right where I want it now.
To MarkL, I would ask, does the Red Ceder reduce the bass any?
How much did you use though? And which kind? Too much will definitely have a strong effect, but the amount I ended up putting in was extremely thin to say the least and I used the Mountaim Mist. Actually, to be honest, after one person suggested that the extra padding soundstage fix might be related somewhat to the sibilance I tried taking that out just to see and I must admit I liked the sound better without it despite the negative effects on the soundstage (but then the Denons aren't bad even stock in this respect, just not ideal.) I used bits of the stuffing he put in there for my padding (at least I presume this is Mountain Mist since I can see no reason it would be anything else.) I noted that the stuff I took out does at least sound better than the cheap stuffing I had on hand. Here's the wierd thing though. I really can't explain it, but I'd swear that with this the sibilance decreased some tiny amount further from the stuffing. Again I emphasize the fact that I have AT MOST, the same amount as in the original mod thread and I'm quite certain that it's actually even less (I originally thought about 1/3, but now I think maybe more like 1/2 or even 2/3, but still less all the same,) so there's no way it's too much... Maybe it's just my ears being wierd again.
As for cable choice, I did consider the Mogami Starquad once but after talking with fellow audiophiles, most reckoned that it might be too dark for my Denon. Then someone recommended the Kimber 4TC as it has a good value/performance ratio although it was an usual choice considering its nature as a speaker cable first and foremost. It's warm cable no doubt but I'm really happy that the 4TC improved the midrange by quite a bit and made the bass punchier while not skewing overall presentation too much to the dark side. What kind of Mogami cable did you choose for your Denon anyway, Nazo? |
Too bad it seems that this D2000 has a very narrow treble spike that I can't get rid of no matter how much modification I've done. This contributed to sibilance that rears its ugly head now although curiously, it doesn't occur all the time and only occasionally. If switching to wooden cups can fix this, I'm going to be one hell of a happy camper. |
As for the stuffing, I did try it but I found that it sucked out too much bass on top of making things very bright so I removed those polyester pronto. |
