Xcalibur255
- Feb 4, 2008
That's the main power transformer, and that is not normal behavior. Some transformers do exhibit a bit of mechanical vibration and hum which is considered normal for them, but not at the level you're suggesting. What tubes are you using at the moment? It's possible to push the transformer over its limits with certain rectifier tubes that draw too much current. If it's doing this with the stock tubes or with any 6SN7 and 5Y3 combo then I would be reaching out Moon Audio or Dennis for support.
