rgs9200m
- May 15, 2006
Thanks for all that Mr. Rudi! I appreciate the help very much.
If you put a pot to it's max position then you are effectively bypassing it. A tiny part of the resistive track is still in the signal path but it should have no effect.
If your source is a proper preamp i.e. with an output voltage in excess of 6-7vrms, then I'd recommend using the volume control on the amp at least a bit. Many amps don't like to "see" such a high input voltage and may start to misbehave. The Stax amps have no issue with this but not all amps are equal in this regard.
I for one have a source which is a true preamp and I back it off to the standard 4Vrms output and then adjust with the pots on my amps.
Just a question here: I would assume the Eximus DP1 DAC has an analog output that bypasses its own volume control, so the Stax amp's volume control could be used for attenuation.
So would not that be preferable to using the Eximus volume control with the Stax amp's one set at the maximum, because wouldn't that be putting 2 attenuators in the path, even one set to the maximum?
I wonder if you experimented with this configuration.
Hello, I'm new here!
I'm thinking of upgrading my 25 year old Stax SRD-P driver to a new transistor or tube driver. I'm using it with a pair of Lambda Pro's of the same vintage. Can anyone tell me how long the tubes in Stax driver units are rated for?
thanks.
There is no official rating for the tubes but they should easily last 10-15 years with normal use. I've had 25 year old amps come through here still with the original tubes and they still tested ok.
I occasionally use my McIntosh C2300 tube preamp installed with vintage Gold Lion B759 12AX7 tubes and use SRM727II as power amp for the SR009, with the Esoteric K-01 as source. This is much better than purely connecting to the SRM 727II using the Zodiac Gold in my study room. However the preamp is mainly used for my speaker setup so this luxurious setup does not get heard too often, as the study room setup is more convenient. I will compare the above combo with the BHSE when it arrives this month. I would be reluctant to use the BhSE as power amp as I think turning up the BHSE to max volume would not be very healthy for the EL34 tubes and the amp itself?
