vYu223
- Oct 2, 2005
You're welcome. The thread that Ace o' Spades posted (http://www6.head-fi.org/forums/showthread.php?t=202191) gave me inspiration to finally try DIY foamies, since it was so much easier (and since I have worn out stock iM716 foamies already). I was never really willing to go through the trouble of getting tubing for the inside of the foamies.
I used the Howard Leight Max Lite earplugs. I think they are also polyurethane. http://www.hearingportal.com/product...ucts2.asp?id=5
What I did was I put a heavy school text book on top of them to flatten them. Then I used scissors to cut them to the length I needed them to be. After I waited for the desired pieces to expand, I took those pieces, stood them on their bases, and flattened them again with the textbook. Now that the pieces looked like wafers, I put them on top of an eraser and pushed a needle through each of them. I waited for them to expand on the needles (looked like marshmellows
). For each of the pieces, I put another needle and a toothpick through the same hole, tried to expand the hole big enough so that I could squeeze the old foamy's "stalk" through it. IT WAS A PITA!!! But when I finally got the foam onto the stalk, I was pretty sure that, as the hole is only needle-thin, the foams would not fall off of the stalks.
Rolling the foamies are now easier than ever. I must say that rolling the stock foamies were a PITA. The stock ones expanded way too quickly and were difficult to compress. These Max Lite DIY foamies compress easily with the lightest touch, and expand pretty slowly. They are also super-soft.
I believe that they add more bass and warmth to my iM716's, all while maintaining the crispness of the highs.
Originally Posted by jSatch Thank you for the kind words vYu. Between the podectomy and the DIY tips, these phones are really getting to sound pretty special. Cheers- |
