Thanks slex for the (encouraging!) response.
Np,pls note while using idevice is best to enable airoplane mode and just keep the wifi on.
Thank you for the info.
One other question you website lists only 1 dealer for your products in Canada (Audio alliance Inc.), but their website says "We do not sell to the public".
Where else can i buy your products, Amazon.com and other U.S. company's will not ship your product to Canada.
Go here:
http://www.audioallianceinc.com/pages/find-a-dealer
Enter your details and select iFi from the drop down. An answer will come.
(This is the reply you will get from iFi. That's why they have a distributor. One does not buy a dog and then bark oneself when someone comes to the door.)
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Would adding iFi Nano iUSB3.0 to the chain with my Marantz-HD-Dac01 and Singxer F-1 make any noticeable difference in the sound quality?
Yes.This device also works with USB2.0 -connection, right?
Is there any difference in the sound quality when using USB2.0 - compared to USB3.0 -connection?
The nano iUSB3.0 is the more future-proof solution because it supports USB3.0.@iFi audio Would using the original iUSBPower in conjunction with an iPurifier2 be comparable to the nano iUSB3.0 or micro iUSB3.0? This would be in a setup feeding an iDAC2 > iCAN SE. The reason I ask is that I can pick up either the nano iUSB3.0 or iUSBPower/iPurifier2 for about the same price used. The nano iUSB3.0 is obviously the more elegant solution, but I'd be ok with more devices on my desk if the iUSBPower/iPurifier2 combo yielded better results.
As said above, it depends on the USB cable going into the iDAC2.Also, in this scenario would the iPurifer2 be best utilized on the input of the iUSBPower or on the input of the iDAC2 after the iUSBPower?
For immediate distribution:
nano iUSB3.0
Flagship technology in the US$200 sector
http://ifi-audio.com/portfolio-view/nano-iusb3-0/
Southport, UK – 11th February 2016
Total Audiophile USB Solution: nano only in price & size
For $500 to $5000 usb devices, the nano iUSB3.0 is the one-stop, future-proofed solution. It is the sibling of the flagship micro iUSB3.0. It operates in all USB modes to 5 Gigabit USB3.0, supplies pure, clean power and reconditions the USB data. The USB3.0 active chipset at the heart is backwards compatible with USB2.0 so all USB devices - DACs, Mixers and DJ Controllers benefit.
Using the flagship micro platform, the nano iUSB3.0 is the class-leader in the sub US$200 segment:
- Audiophile USB3.0 Ultra-speed (5.0Gbps) and USB2.0 active USB repeater.
- Signal REgen®/REbalance®/REclock®.
- Active Noise Cancellation® military-grade circuit, ultra-silent 0.5uV (0.0000005V) noise floor.
Features
- USB3.0 Ultra-speed (5.0Gbps) active USB repeater chipset
- REclock® eliminates jitter, restores suppresses frame and packet noise
- REgenerate® the USB signal
- REbalance® re-corrects USB signal balance to cancel DC offset noise
- IsoPower® pure, clean USB power line
- Dual-Port® separates power and digital signals with dual-headed USB cables
- PowerStation® new, pure powerline with 3-stage sub-sonic noise filter
- RapidCharge® USB Bus Charge 1.2 compliant (2.1A total high-power)
- iPower (9V) exceptional, ‘quieter than battery’ power supply
Specifications
• USB 3.0: 5.0 Gbps
• USB 2.0: 1.5, 12 & 480 Mbps
• Output Voltage: 5V±0.5%
• Output Current: 2.1A
• Noise floor: 0.0000005V (0.5uV)
• Input Voltage: AC 100V – 240V, 50/60Hz (iFi iPower 9V DC included)
DC 7 – 18V DC @ 13.5VA (including 12V car power)
• Power Consumption: < 15W (includes powered USB devices)
• Dimensions: 87(l) x 68(w) x 28(h)mm
• Weight: 141g (0.31 lbs)
• Warranty period: 12 months
Specifications are subject to change without notice.
The retail price of the nano iUSB3.0 is US$199 (ex-tax) or Euro225/£175 (incl VAT).
For the first 199 customers worldwide, we are also offering a special launch bundle of nano iUSB3.0 & Mercury (0.5m); at US$249 (ex-tax) or Euro275/£225 (incl VAT).
Was thinking, is it better to just use the iDefender3.0 + Nano iUSB3.0 only?
