- Mar 20, 2013
Hello All,
While I am waiting on the great people over at iFI Audio tech support, thought I would post a couple of observations I am seeing with my new setup having replaced a non DSD M2TECH Young DAC with my new IDAC2 which I have to say, I am loving the sound!!
My setup is as follows:
PC running JRiver MC 21 --> Mercury --> IP2 --> iUSB2 --> Gemini --> iDAC2
Question I have, is about the LED lights on the iDAC2 and iP2. How have you all seen these LEDs display based on your usage? For example, should the play light remain lit on the iDAC2 when no audio is being streamed from the PC? Mine always seems to remain on and colored to the last audio resolution file played back. So for example, if I played a 16/44/1kHz file, it will remain green even though I stopped playback on JRiver.
Also, should both lights (Green and Blue) on the iP2 always remain in an on state when no audio is being played back from the PC? I would expect the iP2 power light to be on drawing power from PC but not the data light when no playback is happening.
Last but not least, does anyone hear a little electrical hiss noise when listening to quiet passages of music in the background at a higher volume level using headphones? I guess I expected a truly dark black background especially given the setup I have which I have to confess, I was using iPhone earbuds (!) for my test but still expected things to be quieter in the background.
Anyone experiencing similar behaviors? Looking forward to your feedback in advance...
Cheers,
Vin.
Hi,
The iDAC 2 Headphone output has around 3.5V maximum output with around 114dB SNR.
Meaning if a headphone is around 105dB/1V it should be completely silent, but if the headphone is (for example) 125dB/1V some background hiss will be audible.
With Apple Earpods, these are 122.5dB/1V. With the iDAC 2 at max output this will produce > 133dB, so the background noise level would be around 19dB(A), so like a very quiet PC fan from 1m. So with this setup, this there is notihng untowards.
Cheers.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
