I am happy for you!
What brand/headphones are you using?
I am not going to say this because i want to spoil your happiness of your new Kimber USB cable , but when you are listening to the Kimber USB incl iPurifier 2 , then just for fun then switch to the stock Ifi blue USB cable and see if you can hear any difference, because i can bet money on that it is your brain that focus on different things each time you listen to the same track, and gets even more focused when you know that there is a new USB cable in the setup.
Just a notice and off topic:
There have been serious blind tests where a trained group of listeners have listen to a song and each ten times. During the test the scientists have told the group that they have changed something in setup, like for instance a cable , amp , cd - player or even the speakers.
The group have during the test filled in to a test blanket if they thought that the sound got worser or better in a 10 grade scale with 10 different questions to fill in.
And the result in the end of the day the scientists could distinguish a very interesting pattern from all in the test group just after the second listening to the same track, all taught they could here a significant improvement in different areas vs the first listening and so on..
What the group did not know of was that the scientists hadn't dune anything with the setup, the group had been listening to the same untouched setup with the same track 10 times in a row, but their mindset have tricked them to believe and their brains have focused on different things in the music each time the scientists have told them that they had dune something with the setup.
Some nice input that needs to be enlightened from time to time, and great to know of just..
So please go back and try and see if you hear any difference.
Have a great one!
