marcus1
- May 2, 2005
Thanks for your reply. The reason I asked is that I normally use my Micro in line direct mode to feed my stereo amp and had never bothered with the digital filters as I couldn't hear much difference between them but I recently did a 'tweak' on my Uptone Regen (replaced the 5v power supply with a LiFePO4 battery) and this upgrade (to the Regen) was amazing.
I was testing the tweaked Regen (listening with headphones) and was playing around with the filters and now could hear distinct differences with different filters selected so that's why I was asking about the filters being active in line direct mode.
My media player is the Foobar 2K and I have the SACD plugin installed so everything is converted to DSD. I haven't put the Micro back into my stereo system yet but at the moment I prefer the DSD 'Extended' filter selection (I'm assuming that in the DSD Extreme/Extended/Standard (analogue) range filter selection that the 'Extended' selection equates to the 'Minimum-Phase' selection written on the Micro).
What do you mean by 'digital filters'?
A lot of folks are getting confused and thinking that XBASS and 3D must be DSP. They are not and they are not active in direct mode.
If you mean the digital filters in the DAC - standard, minimum phase and bit perfect - these are always active.
