Hi all,
Major case of feature creep - so we are going to aim for prototype for CES and then launch in Mar.
When we have anything close to soup, we'll put it up here.
The next new product is the Retro and that is coming in November.
Okay, not fully soup, but here you go as we're in a good mood today!
iDSD mini | | | | |
Fully-Balanced DAC (USB/SPDIF/AES-EBU/Bluetooth) | | | | |
Formats: | 44.1/48/88.2/96/176.4/192/352.8/384/705.6/768KHz PCM | | | |
| 2.8/3.1/5.6/6.2/11.2/12.4/22.4/24.8MHz DSD | | | |
| DXD | | | |
Filter: | PCM: Standard/Minimum Phase digital, Bitperfect 1, Bitperfect 2; selectable | | | |
| DSD: Standard/Extended Range/Minimal analogue, selectable | | | |
| DXD: Bitperfect Processing, fixed analogue filter | | | |
DAC: | Quad Core Dual Mono Bit Perfect DSD, PCM & DXD DAC by Burr Brown in current output mode (4-DAC Chip; 8-Channel; 16-Signals) | | | |
Clock: | Ultra low jitter Crystal Clock (rms jitter < 300 Femtoseconds) | | | |
Analogue Stages: | Balanced fully discrete Class A - Non-Feedback I/V conversion by single BISS Supertransistor | | | |
| Balanced fully discrete Class A - Non-Feedback Line output buffer using J-Fets and BISS Supertransistors | | | |
| High Speed current mode Class A Headphone Buffer with balanced fully discrete Class A - Non-Feedback input buffer using J-Fets and BISS Supertransistors | | | |
Volume Control: | Balanced 4-Way precision analogue by ALPS, Remote Control, can be bypassed for Line Outs | | | |
Audio Path passives: | Tantalum Oxide Thin Film thin film surface mounted resistors, | | | |
| TDK high stability C0G surface mounted capacitors | | | |
| Panasonic PolyPhenylene Sulfide stacked film surface mounted capacitors | | | |
| Elna Silmic II Electrolytic Capacitors | | | |
Input: (selectable) | USB 3.0 | | | |
| compatible with iPhone,iPod, iPad and Android Devices USB-OTG# | | | |
| SPDIF RCA/Optical (only PCM up to 192KHz) | | | |
| AES-EBU Balanced | | | |
| BNC SPDIF Unbalanced | | | |
| Bluetooth with aptX | | | |
Audio System Support: | PC - ASIO 2.2, WASAPI, Kernel Streaming (KS), Directsound | | | |
| Mac - Core Audio | | | |
Output | XLR True Balanced Audio (Output adjustable 4/10V @ 0dBFS [+14dBu/+22dBu]) | | | |
| Audio RCA (2V/5V @ 0dBFS) | | | |
| 6.3mm Headphone 4V/10V maximum output | | | |
| Headphone Output Power 4,000mW/16R max. | | | |
Dynamic Range: | TBD | | | |
THD &N (Line) | TBD | | | |
THD &N (HP 100mW) | TBD | | | |
Output Power (16R): | > 4000mW | | | |
PowerSource: | External DC 14V (compatible with 12V Battery systems) | | | |
Power Consumption: | < 15W | | | |
Size: | 220mm x 62mm X 210mm (W X H X D including feet, knobs and connectors) | |
Cheers.
