- Mar 20, 2013
Thanks for your advice.... I will report here ...
Please do!
Stay updated on iFi audio at their sponsor profile on Head-Fi.
I just install the Ifipower for my starting Point systems NOS.dac and the ifipower is better than my battery, the noise level lower, without mistakes... I am very pleased... My system is cleaned and treated all along the electrical grid by my own methods already, then it was easy to detect the improvement against my lithium battery, first and foremost with dynamics, and more detailed and better separation...It was a surprise for the price...
The beginning and the end of the highest audio experience for me in my travel trough music was first and foremost noise control along the electrical grid and along the audio grid, even for a relatively modest system like mine...Buying costly product is not the only solution for this living experience... Ifipower is a perfect demonstration of this possibility at low cost...
Thanks to people of Ifipower...
P.s. I must say that placing some Tourmaline, Jade, and Shungite stones on the Ifipower transmute the clarity gained with a lower noise floor in a more musical, and velvet sound without lost of details...
Hello @iFi audio
When I subsequently disconnect the source(USB or audio input jack) the noise disappears. Therefore, I suspect it's their power supply responsible for that high noise floor (reverse power). Is that assumption correct?
Apparently, they use a 16V switching power supply. My question is, is your 15V iPower capable to drive them? I suspect the 1V drop (from 16V to 15V) should be within the device ''tolerance''?
As far as I can see, you produce 2 variations of 15V iPower - one 15V/1.5A and another 15V/4A.
Is the whole range of iPower power supplies (I'm referring to those with the wall-wart design - not to the ''brick'' 15V/4A) rated at 23VA (Volt-Amps)?
Thanks for all your help and clarifications!
Thanks for getting back to me!Might be the case, but not having your product we can't say for sure.
We advise to direct this question to the manufacturer of your product. They probably will say that 15V will do, but we'd ask nonetheless.
Was this a typo by any chance? Was it about 230V (not 23V)?
Sure thing, anytime!
the 15V version outputs 1.5A max. Is that correct?
That's what I'm going to do.It doesn' go above 1.2A, otherwise it wouldn't be within specs we list. You could use 15V/4A. It's not listed at our site yet, but we have them.
At the time of writing I can only find the 15V/4A on ebay from German sellers...
Will do!
Hi Wayne.Cant wait for your feedback G_T_J,
I'm in a similar scenario as you.Was wondering if the ifi iPower Plus could improve on the MM-1.
Regards Wayne
Will do!
I'll just wait for the reply from B&W and I will contact you directly on your website.
Thanks once again!
