regicide
- Aug 22, 2011
Hey all
so I am looking into getting a decent pair of IEMs, I currently user either my grado sr80i for portable use (open so useless on a train, but love the sound) or my skullcandy FMJ (RUBBISH sound).
I am aiming to spend about $200 USD.
I listen to mostly rock (60-70%), electronic (20%), classical(10-20%).
The IEMs cannot have overpowered bass, detail is the goal and muddyness is the enemy.
They also need to be able to stay in while im walking, my FMJs slip out all the time.
They will be used from a clip+ possibly with a cmoy if needed (just built it).
IEMs i'm considering include:
If you know any others and/or which of the above best suit my needs, PLEASE shout out.
EDIT:
after finding the livewires/fidelity-customs I am very intrigued to say the least, and although they are stretching the budget a little, for customs it could be worth it if the SQ is on par with those mentioned above.
sorry for another thread, but I have expanded my budget and am considering customs
http://www.head-fi.org/t/572070/good-customs-for-rock-electronic-classical-for-350usd
Thanks in advance!
~Chris
- Shure 315
- Brainwavz B2
- Earsonics SM1
EDIT:
Thanks in advance!
~Chris
