I see there are still people who love SR-1, and want to have more out of it.
So a while back I thought perforated pads were going to do great, in which it did.
But in my review I was saying that I really wanted the SR-1 to be just an Opened back headphones instead of semi-open back ?
Well, how about me sharing the modification that would bring you an open back SR-1 ?
This should be a one way trip....irreversible. You are all responsible for your tinkering and this guide can not hold me responsible for what you are doing or have decided to do and or any damages that can occur
Have fun!!!
Improvements : Soundstage and better openness!!! Whatever else that benefit an open back headphones.
Negatives ? None, at least not to my opinion
materials needed
1/ Back acoustic resistors....well, you don’t exactly need any resistors at all. Only need dirt filters more like, so the more open is the better. I choose to go with what I have here in my garage. The Weed barrier and can be found from homedepot for cheap. You can chose other better sophisticated materials that isnporius and allow air to vent through
https://www.homedepot.com/p/Vigoro-...ape-Fabric-with-Microfunnels-1242RV/302720132
2/ Next care skin tape. This tape is very reliable as I have used it to modify MSR Z7 MKI years ago and still staying great
https://www.target.com/p/nexcare-sensitive-skin-tape-blue-1-in-x-4-yd/-/A-14796593?ref=tgt_adv_XS000000&AFID=google_pla_df&fndsrc=tgtao&CPNG=PLA_Health+Shopping_Local&adgroup=SC_Health&LID=700000001170770pgs&network=g&device=m&location=1023631&ds_rl=1246978&ds_rl=1247077&ds_rl=1246978&gclid=EAIaIQobChMI8t2CoPD15wIVBpyzCh1jogiGEAQYBSABEgK3o_D_BwE&gclsrc=aw.ds
3/ Scissors , screw drivers and different needed tools
Procedures
1/ take off the pads
2/ There are 2 main screws on the Yolks from side to side. Take it out and extend your headphones housing straight back out, you will see the turning mechanism. Match them up and pull the frame out, your housing should be separated and pullEd out
3/ Turn to the front face, you will see 6 screws being covered up by black tape. Peel them away and then unscrew all screw. Be gentle as the housing is Plastic and if you are reckless, the screws may trip
4/ Now you can separate the putter housing, the Net protective housing, and expose the driver back. You will see the Felt being pasted at the back of the driver. Do not use any heat or any funky things, use Tweezers and carefully lift a corner then use the back of the bigger end on the tweezer and continue peeling. You will ruin the Glues but you should be able to preserve the Felt. Don’t worry, if you want, you can then use it again with the next method
5/ Now use this Felt as a Sample and cut your Weed barrier into Circle of the same sizes. Then using the Tape and cut it out, tape up the Weed barrier into the replacement of the stock felt like this. Remember to use it discretely and don’t block the air holes too much. It should only be enough to cover the plastic. The barrier is directional, I use the face in so the air can easily be pulled in
6/ repeat for the other side and put them back together. Pay attentions on the Net protector, there is a cut out for the MMCX entrance, put it on the driver first and make sure it fit the MMCX, then put onto the putter plastic frame.
Voila!!! You have transformed your SR-1 into a full blown opened headphones
If you want to reuse the stock Felt, you can take off the Barrier and tape the stock one up under this fashion. However it can only be done once, as it will further damage the felt. The next time you wanted to, you will have to use other Felt materials that is 100% blocking similar to stock
