Ibasso PB5 the next dedicated portable Amplifier
May 13, 2024 at 5:17 PM Post #466 of 486
Hi,
Joined the PB5 team but what’s up with charging. It doesn’t work with my Apple 18w charger and Quest charger. Works with my old 5s charger which can only do 5v/1A. Tried with my Anker 100w charger which can do 5v at higher A from USB A and works with that.
It doesn't work with some of the quick chargers. I use a few 2 and 3 amp chargers with no issue.
May 13, 2024 at 6:31 PM Post #467 of 486
Hi,
It seems to only work with QC or regular chargers, and only USB-A to USB-C. It will not work with Power Delivery.
May 13, 2024 at 6:58 PM Post #468 of 486
Hi,
Yeah, PB5 only made to work with usb-A to usb-C cables.
Not USB-C to USB-C.
I unplug it and replug it quickly before I start using it so it charges as its in use.
I never have had it turn off on me during a normal sitting.
May 13, 2024 at 8:11 PM Post #469 of 486
Not USB-C to USB-C.
Oh ok, that’s ok but I really wanted to get away from USB A and now I have to hold on to that one USB A to C cable.
Had a quick listen and it does add significant sub bass. I like bassy amp like Schiit Mjolnir 3
May 15, 2024 at 12:57 AM Post #471 of 486
I wish they had some indicator to give indication on charge level of battery…right now there is no way to know the status of battery.
May 15, 2024 at 2:44 AM Post #472 of 486
Does somebody use this amp in a desktop setup? Does it have any way to handle the battery if one would run it constantly on external power?
May 15, 2024 at 7:07 AM Post #473 of 486
I've been using this as my desktop amp w/ my Gustard a22 DAC.
I turn the PB5 off when not in use, and I haven't found a shift of sound with warm up.
After turning it on for a session, I just unplug & replug the charging-cable.
May 17, 2024 at 7:50 PM Post #474 of 486
This is one thick and heavy stack. The thickness can be felt in sound as well.
I like to roam around when listening to IEM and I love the bass impact of this stack. PB5 to IEMS is what Schiit Mjolnir 3 is to headphones. Both are fun and bassy. So would love to carry this while listening to my IEM on the move. Only issue is to hold it together when on move. Ideas from experienced users are welcome
May 17, 2024 at 8:33 PM Post #475 of 486
Classic solution is to use velcro. Stick the rough side on the Ibasso PB5 and the soft side on the dap (soft side on dap incase you ever use it alone, so it can slip into a pocket).
May 18, 2024 at 8:03 PM Post #477 of 486
Great advice. Adding to it: if you don't like to stick Velcro onto your expensive device or even onto your leather case, wrap wide one-wrap velcro around each of your device, stack them, and then one-wrap them together.
May 19, 2024 at 7:49 AM Post #478 of 486
I wrap them, it is more secured, but also can leave indent on the leather cases. But that’s ways better than risk dropping it lol
May 22, 2024 at 10:52 AM Post #479 of 486
Which eletech cable are you using there if you don’t mind me asking? For your xe6?
May 22, 2024 at 11:22 AM Post #480 of 486
