I came across this when researching the topic of grounding via interconnects:
"As long as interconnects remain in place and any of the components are grounded then there's not much risk"
This is false and taking this approach can create a false sense of safety. There are several things wrong with this notion. The most prominent are:
1. Signal grounds are not always tied to chassis ground.
In this scenario, if a ground-defeated component experiences a fault, the dangerous current will not flow through interconnects. Even worse, a ground-defeated component with signal ground tied to chassis ground could fault, and the current would flow via interconnects to another component that doesn't have signal ground tied to chassis. Now you have TWO components with dangerous current flowing through them.
2. Most interconnects cannot handle fault current.
The typical audio interconnect (the even really expensive examples) uses thin-gauge wiring designed for low voltage/low current, with connectors also designed for low voltage/low current. A ground fault involves high voltage/high current. Even if a fault is shunted through an interconnect, it may fail/melt/catch fire before a fault can travel to a grounded component and cause a circuit breaker to trip.
I am a little worried of using an anearthed PC with the DAC with IC's providing ground via the amp
. The above suggests that this is a band-aid fix to the ground loop problem.
