Sound Eq
- Nov 9, 2013
what source/amp do you use with your lcd-2?
i use ifi dsd micro, alo mk3 B, and I use neutron music player
I grave for big bass, and and warmth to music
The original post is several years old now. Is there a new method/software that has been discovered or should I just follow the original instructions from 2009?
I will be using Windows with Foobar (I guess?)
I will be plugging my Koss Pro-DJ200 directly into my laptop
Any recommendations are appreciated. Thanks!
hi sorry for the old post bump...I just bought these brainwavz headphones and would love to know how I could quickly copy these settings into neutron for Android app.. would any body know of a preset file for these headphones? Many thanks....Hmmh, equalization can totally correct "flawed" sonic balance, in my case of Brainwavz M2.
This makes these show all their excellent qualities that are masked by overblown bass...
Funny that w/ Hybrids (included) the highest frequency hump is completely out of proportion - gets extra 6 dB - and almost impossible to equalize.
Latest curve w/ Comply T-200 (not simplified yet):
Comply also round out the bass - it loses some harshness where not warranted. (What I call ringy bass.)
Note that I always attempt to keep 1kHz at 0 dB.
If you're in the market for a hardware parametric equalizer, and have balanced connectors on your DAC and amp, I heartily recommend that you check out the Varicurve FCS-926. There are currently several of them listed on eBay.
I'm thinking of going with hardware as well, but not everyone has balanced connectors. Does this mean that we would have to go the software route?
hahahaha bodhi.....ok then...it seems you have knowledge of working of ears..but not of soundThis is ISO 226:2003, which by the way is measured using speakers, not headphones:
The resonances of the outer ear as well as the inner ear are apparent.
What I'm saying is that if that's how sound is perceived in the real world (not flat), what would be the purpose of EQing flatness into our perceived audio resonse?
For anyone looking for a recommendation on a hardware equalizer...
I just got a used BSS Varicurve FCS-926 off of eBay and am very pleased with it. Did the sine sweeps and adjustments as per the OP, and eliminated the high-frequency peaks on my HD800's, and boosted the bass a bit. Made the headphones wonderfully listenable.
Features of the unit:
• 6 bands of parametric equalization per channel
• frequency selectability equivalent to a 210-band graphic equalizer
• balanced inputs and outputs (note: no unbalanced i/o)
• backlit LCD display shows equalization curve graphically
• intuitive controls; not too complicated
• 50 memory locations for presets (handy for storing settings for multiple headphones)
• real-time, 30-band spectrum analyzer graphically displays your music, sine sweeps, etc.
I wanted to go with a hardware equalizer so I could use it with all my sources, including computer (via USB) and iPad (via Airplay/Airport Express). I researched hardware equalizers, and came upon this one, which doesn't seem to be mentioned anywhere else on Head-Fi. I don't believe these are manufactured anymore; my unit is probably about 20 years old. Sound quality is excellent; no noise, etc.
