MalVeauX
- Apr 29, 2011
How is a graph not reliable? I'd say a review is much less reliable than a graph. A graph is as objective as possible (if it's accurate, of course), it doesn't tell you if it's good or bad, it doesn't give you an opinion, it gives you values. You can say it isn't really as important as a review, since that one relates more to what the buyer wants (how does it actually sound), but that doesn't make it more reliable. Human opinion changes, and therefore is unreliable =)
Heya,
I appreciate what you're expressing, however graphs do not take into account the enclosure of the headphone. There's a lot more to what is actually heard than what is measured by a set of microphones. Some headphones look like they should be bassy according to a graph, yet are not. Others don't even look that bassy, yet are out of this world bassy. Comparing on a graph, seeing a few dB difference in the response, shouldn't result in out of this world differences, when you can do that on an equalizer and not get that same difference with the same jump in dB on a similar frequency range.
Relating a graph to a headphone that you've heard however is quite useful for discovering whether or not the graph is at all close to what is perceived to form a better relationship of information for the next person.
Very best,
